Author Topic: Rollei R80 carousel slide tray for P360AF projector  (Read 25544 times)
MJL
« on: December 11, 2018, 09:29:51 PM »
I still use my old Rollei P360AF slide projector due to its' better lens & light control over Kodak's.  However I can never figure out how to load slides into their vertical R80 carousel slide properly.  Kodak is easy, just drop & lock with the top ring.  The R80 has a fixed half-cover and a removable half-open carousel to hold the slides.  Does anyone here may have a R80 instruction manual or can teach me how to load it?  I search everywhere and got no info on it.
Addicted to Kodachrome, Medium Formats, Polaroid, Russian lenses and big shinny objects.
Re: Rollei R80 carousel slide tray for P360AF projector
« Reply #1 on: August 25, 2019, 12:07:02 PM »
Does the attached help? Doesn't make much sense to me but if you have the R80 in front of you, maybe it will. Seems it's all Rollei supplied anyway.
MJL
« Reply #2 on: October 07, 2019, 11:55:59 PM »
Thank you, Peter!  Mystery solved finally. :)
To insert or remove slides, a pin is needed to keep the sliding metal gate in an open position.
You can image what a pain that will be in the dark.  No wonder the drop in Kodak design was much more popular.
