Author Topic: Why does my color developer keep dying? 😭  (Read 12733 times)
« on: April 01, 2024, 07:25:09 PM »
I use the Unicolor powder kit, mostly because it's cheap but also because it's easier/smaller to store, and I assume it keeps longer than liquid concentrate.
Here are the things I do to ensure that the dev stays as fresh as possible:
1. Keep it in an air-evac container so that there is very little surface area exposed to air.
2. This container is solid black, so it keeps out light.
3. I store it in my kitchen cabinet, which is also dark and is only opened to take out chemicals (B&W as well as color).
4. I keep all hardware for dev & fixer separate (flasks, funnels, mixing rods, etc). I even keep those hardware items physically separated by a few feet at all times.
5. The only items which sees both dev & fixer is the developing tank, and I wash that religiously after every dev cycle. A forumite was present one time that I developed and said that he doesn't even wash his dishes that thoroughly 😂
Despite this, my dev always dies within about a month, no matter how little I use it (these days, it's once every 3 months or so, so I literally get one dev cycle out of each batch).
My next step is to keep the dev in the fridge to see if it's the temperature that is killing it.
Any other suggestions? 😢 At this rate, it would be more economical of me to get my color film lab developed 😢
Re: Why does my color developer keep dying? 😭
« Reply #1 on: April 01, 2024, 11:02:11 PM »
Those air-evac bottles are just the most horrible thing for chemicals.
I had them and hated them all. Even if the manufacturer claims that they help keep the chemistry good for longer, it's just not true.
A few years ago I got fed-up with my developer turning black without being used, so I switched to glass bottles.
I use the IKEA Korken bottles and they have saved me plenty of money and aggravation since I got them. The thing is, plastic lets gases flow through if given enough time. Glass is completely impervious to that. The IKEA bottles come with a very nice silicone stopper and cost only 4$. If you keep them in a dark cupboard, you don't need dark plastic.
As a test, I have some PQ Universal in one of them and it's still light apple juice colored after 2 or 3 years... Normally it's the color of Coca Cola after just two months.
I just spray some air in a can in them until the sound of the rushing gas changes and promptly seal them.
I also wipe the rim of the bottle with a bit of paper towel just in case it affects the stopper.
I have some 3 year old C41 in one of them. I'm going to have to try it out this year... wish me luck!
« Reply #2 on: April 02, 2024, 03:26:57 AM »
IS THIS TRUE??? 😲😲 I've been living a lie?? 🤦🏾‍♂️ Ok, glass it is then 😕
I've never bothered spraying in butane or anything, but maybe I should start doing that.
Phil Snaps
« Reply #3 on: April 02, 2024, 10:52:21 AM »
PET bottles seem to be really good. I use soda or carbonated water bottles that I fill to the brim. They have many benefits: they are cheap/free, don't break, they come in many sizes, and are flexible: when some chemical is inevitably lost you can squeeze them to chase the remaining air, so you can avoid using canned air.
Just make sure you label them appropriately. I remove the label, then write the chemical name in big letters and draw skulls and crossbones :D
Someone on Reddit tested some year-old C-41 with test strips and a densitometer and found it was still fine in PET bottles after a year or so.
« Reply #4 on: April 02, 2024, 03:31:27 PM »
Sadly it is... I must admit that I have been swindled by them too.
Worst part is that the phenomenon has been known since the 1960's...
If you google plastic oxygen permeability -film, you will get plenty of results that explain the cause and effect.
« Reply #5 on: April 02, 2024, 04:52:34 PM »
A long time ago, when Paterson still made chemicals, one of the Paterson guys told me about the plastic bottles and I switched to glass. Never had a problem since.
« Reply #6 on: November 15, 2024, 04:39:04 PM »
Francois, I have to thank you for this advice you gave me. Ever since switching to a brown glass bottle for my color developer, it has remained nice and fresh for over 7 months and counting with no other changes to my routine (same storage temperature/location, no butane to top it off, etc). This gives me yet another reason to hate plastic in general 😁
« Reply #7 on: November 15, 2024, 10:37:27 PM »
I'm really glad it helped.
Since I discovered this and switched all my bottles, I've been getting insane longevity out of the chems.
I have a bottle of mixed PQ Universal that must be going on it's 2 or 3 year anniversary now.
Since I haven't used it mush, the bottle had a strong vacuum last time I used it.
And this was made from frozen concentrate, which is even more surprising!
« Reply #8 on: February 20, 2025, 08:27:34 PM »
Once again I have to thank Francois for his brown glass bottle advice. I'm still using the same batch of C41 (granted, I haven't been developing much, and even though the last time I used it was last November, I've only run about a dozen rolls through it in the last year). Mixed on 4/1/2024 (American date format!! 🤣) and still going!!
« Reply #9 on: February 20, 2025, 09:00:47 PM »
Good to know. Since I switched to glass bottles, I've never looked back.
Moto-uno
  • marvelousmr@hotmail.com
« Reply #10 on: March 08, 2025, 11:04:34 PM »
  This is great news , does anyone here have similar experience with slide developing chemistry ? Peter
« Reply #11 on: March 09, 2025, 01:11:39 AM »
I would assume that the same principle (glass bottles keep air out better than plastic) keeps all film developers safe, since they all seem to hate air 😁 However, I hear that bleach in particular actually likes air (specifically oxygen) so maybe it doesn't matter so much for bleach? I use blix for C41 and I've kept it in plastic this whole time with no complaints.
« Reply #12 on: March 09, 2025, 02:19:19 PM »
So far, I've switched to all glass and I don't see much difference when it comes to the Blix. So I guess it's a lot more robust than the dev, which is not entirely surprising in a way.
« Reply #13 on: March 09, 2025, 07:04:15 PM »
I've been living the plastic lie as well.
Fresh chems have been ordered I'm going to give it a go again.
I was so dismayed by the lack of longevity of the colour chems last year, that I abandoned a project I had been working on.
this gives new hope to going forward and not having to spend a fortune on fresh chems every six rolls.
thank you all!
Moto-uno
« Reply #14 on: April 06, 2025, 08:09:51 PM »
  I've just gone over the instructions that came with my Argentix C-41 kit and it seems to remark that much over a weeks storage may be noticeable . Has anyone used this kit ? Can you verify that you have examples which may make their remarks kinda questionable . I'm not looking for perfection , just good
enough (my colour acuity is less than great :) )
« Reply #15 on: April 06, 2025, 10:56:05 PM »
I use the Argentix kit.
I did notice that they say that color won't be as great after a week, but that's a common claim for all color developers.
The thing is, when they say colors are affected, that this remark is intended for enlarger work and not scanning.
On the enlarger, you have a base filter pack that is calibrated for the paper in use and the negative. If the chemistry is fresh, you'll get colors right with little fuss. But when you use a a scanner, you can throw really crappy negatives at it and it manages to correct them. So I wouldn't worry about it.
So far, I've used so pretty old chemistry without any issue. I usually keep the chems at least a year before throwing them out as I figure that with the seriously old film I pass through it, I won't be able to tell if it's the film or the developer 😁
« Reply #16 on: April 07, 2025, 04:05:51 PM »
BTW, years ago I made a compensation chart based on Reinhold's hand drawn chart (https://filmwasters.com/forum/index.php?topic=8224.0).
I did a non-linear regression on it to get the formula and added an offset so that it more closely matches the times for the Argentix kit.
Here's the link to the PDF on my Google Drive
https://drive.google.com/file/d/1t6S9h0rkQGty3_O7t36rUGclFL8xRyoX/view?usp=sharing
I mostly use it to calculate times for processing at around 32°C (the temperature I get from the hot water tank) and tend to get decent results.
« Reply #17 on: April 07, 2025, 06:13:45 PM »
I recall reading somewhere that blix actually likes air, and you can refresh it by shaking it to mix air into it.
I thought it was here that I read it but can’t find the reference.
Mike.
