Author Topic: Anyone know what this setup might be?  (Read 1080 times)
lharby
  • Hi
    • slackwise
« on: December 30, 2017, 11:12:10 AM »
Hi
The photographer is Paul Shambroom.
You can see the instagram image here: https://www.instagram.com/p/BdTdzCOHwlR
And this is the actual jpg
I took a guess at the logo being Contax? But I am not 100% sure as it is so skewed due to the angle of the image
Everything should be tried once except incest and folk dancing.
lharby
  • Hi
    • slackwise
Re: Anyone know what this setup might be?
« Reply #1 on: December 30, 2017, 11:12:46 AM »
Ah, I think actually the body is Sony?
« Reply #2 on: December 30, 2017, 11:43:33 AM »
Definitely a Sony body. Lens looks like an enlarger lens. Can't see an adaptor between the body and the bellows and I don't think Sony make bellows so must be a custom job.
« Reply #3 on: December 30, 2017, 02:36:05 PM »
It looks a bit like the Hama Spiratone Bellows, but I am not sure.
gothamtomato
« Reply #4 on: December 30, 2017, 02:51:37 PM »
I looked at his Instagram but I wish he had posted a picture he shot with that set up. Otherwise he's just a tease!
« Reply #5 on: December 30, 2017, 03:33:02 PM »
The lens is a kind of Schneider.
What I find odd about the bellows is that they have movement.
I'm reminded that Cambo once made stuff for what they called an digital view camera. So that could be it.
And I can confirm that the camera is a Sony. Just look at the marking for the sensor plane, it's too close to the front to be anything else. Also, the camera is extremely thin.
« Reply #6 on: December 30, 2017, 06:08:52 PM »
The lens is definitely an enlarger lens so maybe the bellows came off an enlarger as well. A lot of enlargers have movements.
If you want an off-the-shelf similar setup then there's this and it'll only cost you 1400 pounds.
And the camera is a Sony A7rII.
« Last Edit: December 30, 2017, 06:11:41 PM by PeterR »
« Reply #7 on: December 30, 2017, 08:59:33 PM »
It could also be a regular lens for the bellows set. These don't usually have any focusing capability.
The frame could be something hand made from various components and inspired by the Horseman LD (http://www.kenko-pi.co.jp/horseman/e/digital/LD.html)
I checked Sinar, Cambo, Arca, Alpa and they all have a different design using base tilt (Sinar and Cambo make them, Arca and Alpa don't)
« Reply #8 on: December 30, 2017, 09:14:03 PM »
Definitely an enlarger lens Francois. You can see the tab that's used for changing the aperture. Here's something similar. It would need to be a medium format lens to allow for movements so probably an 80mm.
« Reply #9 on: December 30, 2017, 10:25:13 PM »
Yeah, you're right... It is an enlarging lens.
lharby
  • Hi
    • slackwise
« Reply #10 on: December 31, 2017, 02:32:26 PM »
Thanks everyone, good work.
He's actually replied to a question about the lens
https://www.instagram.com/p/BdTdzCOHwlR/
60mm Schneider Componon
I might look into the bellows.
« Last Edit: December 31, 2017, 02:35:07 PM by lharby »
