Author Topic: Respooling 400ft of film into 35mm cans?  (Read 1984 times)
Kayos
    • My Blog
« on: April 09, 2015, 09:11:21 PM »
I've found a decent supply of Kodak short ends, ok it's not quite 400ft (yet) but there's  150 ish on the one I've ordered,
Will this fit into a std bulk film loader or do I need to respool it onto a smaller spool before I put it into the 35mm canisters?
Re: Respooling 400ft of film into 35mm cans?
« Reply #1 on: April 09, 2015, 09:29:31 PM »
A 400' film spool is usually about 7 inches (17.8cm) diameter.
« Reply #2 on: April 09, 2015, 09:58:39 PM »
I saw a neat technique today on RFF that I sent to hungrymike. This might be able to help you out!
http://rangefinderforum.com/forums/showpost.php?p=2473329&postcount=1650
« Reply #3 on: April 09, 2015, 10:13:10 PM »
I would find a way to put a crank on the empty spool... it would go faster.
Kayos
    • My Blog
« Reply #4 on: April 09, 2015, 10:14:12 PM »
That looks great, thanks SLVR
Anyone got any empty 100ft cans and cores? I should of given it more thought before I ordered it, at least I can practice ramjet removal on the spare 50 foot :)
« Reply #5 on: April 10, 2015, 12:36:41 AM »
A pair of 35mm rewinds would make short work of it.
« Reply #6 on: April 10, 2015, 02:05:31 AM »
I have a piece if thick string that it's cut to the length of 12 35mm exposures. I pull the film off the spool and measure 1, 2 or 3 lengths depending on what I need. Then I wind it into a canister by hand. It takes about the same amount of time as using a daylight loader. All done in a dark room of course.
« Reply #7 on: April 10, 2015, 11:45:41 AM »
saw this is the polypan f group on flickr. it was creating for dividing those big rolls into 30,5 meter rolls for dayloaders. should work for 135 canister too. I think I've seen Adox use something similar for their test rolls.
album with more images: https://www.flickr.com/photos/nikon_man2011/sets/72157651775818171
« Reply #8 on: April 10, 2015, 11:51:44 AM »
