Ed, what a superb portait! Colours look fine too. A quick test of your developer when doing 35mm is just to take the film leader offcut (which as been exposed to light obviously) and dunk it in the developer for a few minutes, then dunk it in the blix. If it comes out clear orange then the dev is dead, if it comes out brown/opaque then the blix has had it, if it comes out a nice dark black then things should be ok. The best test is to have a spare roll of 35mm used for such tests, shot a couple of frames, snip them off and develop/scan them... but if you're pushed for time then the quick method will probably tell you enough without the need to load up a tank etc, and will at least give you confidence that you'll have something on the negs.
