Author Topic: Make your own 127 film from a roll of 120!! Easy Peasy  (Read 38679 times)
« on: May 16, 2012, 03:11:33 PM »
 I wanted some 127 film for my Yashica 44 and Bencicni camera but coudn't find any in my stash so I kept thinking I had heard of people cutting down film..the articles I had read didn't seem all that easy but I had seen this gizmo and thought there must be a way to use it for film related adventures.  I got one of those cigar cutter gizmos at a cigar,cigarette store. They have an approx 54mm opening which normally closes around the cigar, and two half circle blades normally cut off the end of a cigar..Since I don't smoke cigars...yuk!!..I imagine this is how that works.. These contraptions are about $2.50 so very inexpensive.  You can then pull the halves apart and sand with a bit of course sandpaper one of the little half moon blades so it is no longer sharp and then put the cutter back together..(It just slides back together)or just carefully sand one of the sides without taking the whole thing apart which is what I did cause mine would not come apart..at this point the sanded edge will not cut which is what you want...(both of the blades don't need to be sharp) Next, carefully  slide it over your roll of 120, I needed to trim off one plastic edge of the 120 film roll in order for it to fit into the 54 mm opening. Make sure you have carefull measured to the same size as the 127 film so that you don't make the 120 film too long to fit into the 127 spool..I used TMAX and cut it along the line that read "100" and it was perfect but of course you need  to measure with the  brand of 120 you are cutting since it won't have the same markings on it. Next start turning the cutter in a continuous motion til its all cut, which takes about a minute or less, you will be able to feel when the blade gets to the plastic 120 spool..I started the process in subdued light then went into my make-shift darkroom to finish. Next you have to rewind onto a 127 spool, I carefully removed the "new127" film and then re-wound back on to the 127 spool.If anyone needs pictures of the "contraption" just let me know! hope this is helpful.Attached is an image from the Yashica 44 using cut down TMAX to 127 size.
« Last Edit: May 16, 2012, 03:13:48 PM by Diane Peterson »
Re: Make your own 127 film from a roll of 120!! Easy Peasy
« Reply #1 on: May 16, 2012, 03:18:12 PM »
This is really cool! i never thought of cutting down the 120 like that.
Id do the same but ive modified my Yashica 44 to take 35mm. That and i dont think i have another 127 spool kickin around.
How did you process this film? my film spool doesnt have a notch for 127.
« Reply #2 on: May 16, 2012, 03:32:06 PM »
I have the plastic reels and the metal ones also but never seem to get those metal ones to work right! I just take the plastic reel and keep adjusting til it fits the 127 size....very easy!! If you need a 127 spool I have a bunch..Let me know an address and I will send it along to you..send me a personal message here or go to my regular email...
dianepeterson@cpcinternet.com
ps...can't you revert your 44?
« Reply #3 on: May 16, 2012, 04:00:57 PM »
i could if i could remember where i put all the film tension springs and such that i removed to fit the 35mm cassette in there!
« Reply #4 on: May 16, 2012, 10:31:51 PM »
That's great Diane... I have a couple of 127 cameras I've used in the past with 35mm but your contraption seems way better!
« Reply #5 on: May 29, 2013, 07:25:21 PM »
Thanks Diane, very helpful instructions. A few months ago I purchased a cigar cutter, having seen a video demonstration on Youtube. My cutter wasn't wide enough to fit over the end of the spool and I thought all was lost because I didn't think of your idea of trimming the spool - so now I'm off to see if I can find the discarded cigar cutter !
